Discuss Maintained 6' Emg Light in the UK Electrical Forum area at ElectriciansForums.net
C
cjk
Hello,
I have a 6' foot maintained single emergency light, which is not working. When the battery is connected the light fails to light either when switched live is on or when all lives are off.
When the battery is disconnected, it works fine on the switch live but emergency function of course dose not work.
When the battery is connected the red charging led is on, when disconnected the red if off.
Is this likely to be a battery which needs replacing or a faulty emergency module? Is there anything else I can try/test?
Your profile says you are Training, can you not ask the people who are training you to take a look as diagnosing this should be pretty simple for someone with even limited electrical knowledge.
Reply to Maintained 6' Emg Light in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi So I'd like a maintained emergency light but without the automatic emergency function to trigger in the event of power failure. In other words...
Hello Forum! The building I maintain has some fluoro fixtures with battery backup ballasts. There is a 3-way switch at each end of the hallway...
Hello, Behind a tiny door in our under stairs cupboard we’d like to build a miniature room in which a little light would come on when the door...
