Discuss Marking up socket outlets in the UK Electrical Forum area at ElectriciansForums.net
So is there a standard format for marking up sockets etc?
Ie DB number/ line number/ circuit number? Or can you just call one Dave, another Chuck??
I’ve got a new label maker and wanting to try it out
As long as it's clear and legible you could call them Rita the bi-curious chicken...
DB, Phase for a start or just make it up as you go along once you are paid don't worry about it as the maintenance team will appreciate the OT ;o)))))
I was joking okay......
I use the format of DB1/1L1.
I don't like it when you see sockets and switches with a massive string of numbers and letters giving the full stack up of the distribution back to the main switch, it's toouch unnecessary information in my opinion.
I'm with Dave the simpler the better.
Reply to Marking up socket outlets in the UK Electrical Forum area at ElectriciansForums.net
Hi I’m getting a new kitchen fitted, there’s a existing socket outlet fitted into a pipe chase, for the rewiring of new socket outlets is it...
hi all come across a new build commercial office where radial circuits feeding electrak power track was protected by 32A RCBO at dist board and...
Hi, This post is about my concerns with medical IT socket outlets and want to alert you all if you are fitting them in a hospital. The current...
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
Hello All, I am a homeowner (but not an electrician) and I am renovating a house that has an old CU containing MCBs and an MK LN5725 residual...
