Discuss max demand cooker and heating system in the Australia area at ElectriciansForums.net
K
Kelrich
morning everyone
could someone please help me on calculating max demand on a cooker ran off 6mm t&e off 40amp mcb, the cookers kw unknown but its older than grass!!
also an old fashioned heating system ran off 2.5 t&e off a 16a mcb which circulates hot air through vents throughout the house again kw unidentifiable.
any help would be great thanks
hi specialist unfortunatly i aint got one of those and got no wages to get one 3 kids have bankrupt me this chrimbo haha will invest in one soon tho cheers
just need the total max demand on my eic for my assessment worked out sockets lights etc just stuck on the above items as theres no identification on them, they were installed in 1972 so you can imagine the state they in
Ooh mate, i know exactly where your coming from lol. Got 3 girls of my own;) Just thought that maybe you'd forgotten about doing it that way lol, if you want a clamp meter for occasional use they do a small 1 in Maplins for £13.00 & according to some of the guy's on here it's quite good.
Older cookers if I remember rightly were about 1.6 to 2 kw per ring & the oven about 3 to 3.5kw. The forced air heating probably about 3kw. But are you sure it's Electric forced air & not Gas / Oil useing a fan for distribution ?
thanks specialist i,ll look into it cheers, other than buying that its not possible to work it out without knowing the kw of the equipment
Well yes as Spark 68 has said above. Do you by any chance have a Make / Model for the cooker ? you could probably find out from that.
sorry specialist only got half of your reply before, dont think any gas or oil is involved i will get back to you in a few mins, adding the breakers together gives me 116a, main fuse is only 60a oviously not everything will be on at the same time so would i put 116a onto the eic, if i use diversity iam still stuck on cooker and heating because i still need the kw
Reply to max demand cooker and heating system in the Australia area at ElectriciansForums.net
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Doing a lot of EICRs at the moment and have came across what I'm sure is a common enough problem. In an off grid rural cottage I have a TT system...
Basic question to see if what I wish to do is correct: Client wants to build (or is building) and outside room (roughly 8m by 4m) to be used as a...
Hi, I would appreciate some views on the following issue I have. The Cooker radial in a house has been wired in 2.5mm T&E, to save the expense...
Hi all, wondering if anyone can help me with a recent issue I've had with electric UFH in a small flat. Found that when the UFH starts, the RCD...
16K
