I wasn't suggesting that you would. For a start the induction hob won't be using anything like 40A.at home have the induction hob (40amp), two showers 40amp each and a lot of other things running and dont have a problem on 100amp service head.
My large Electrolux induction hob shares a 30A circuit with my oven. And I have no doubt that the load never even approaches 30A.
I was merely pointing out that unless things are going to be used simultaneously then there is no need to just add the loads together. Furthermore, with an electric shower you are likely to be in it for 5 or 10 minutes, and so there will be no significant heating of the cable. Overloads which are likely to last for an hour or more are of far greater concern.
Small overloads of short duration can essentially be discounted.
