Discuss metal boxes earthing in the Electrical Forum area at ElectriciansForums.net
I never got that. The box had no lug.no need to earth the box S LONG AS IT HAS AT LEAST 1 FIXED LUG.
You are making a suggestion, not addressing what I asked.then add some od dusty's earth wore. got to be roght.
So how are you going to fix the accessory if the box has no lug, replace the box fixes both problems in one goI never got that. The box had no lug.
It has no earth lug. The terminalSo how are you going to fix the accessory if the box has no lug, replace the box fixes both problems in one go
They ‘should’ be parked in the earth terminal on the boxThere's a new build estate around here where all the switches are 2 plated and the neutral's and earth's are in connector blocks in a metal back box.
but not if the faceplate is metal and is itself earthed.If the metal Box is not earthed then a C2
There are threads on this subject already, such as Back box earthing - https://www.electriciansforums.net/threads/back-box-earthing.176847/I have seen a few metal back boxes that have no earth terminal lug. Do the regs state the metal back box must have an earth wire to it? The earth on the socket/FCU is earthed to the backbox via the socket faceplate securing screws.
Reply to metal boxes earthing in the Electrical Forum area at ElectriciansForums.net
