C
Crosswire
Only for fire FP200 fire alarms, or for all cables?
Phoned ECA tech support on this, they couldn't say!
Prysmian Cables FAQs
What clips are required for FP200 Gold®?
The new FP FIREFIX fixing system is the fastest way to install FP 200Gold® cables - using Spit Pulsa® gas nailing technology. The fixings are made from non rusting stainless steel and are LSOH powder coated.
FP FIREFIX is offered in kit form. Each kit includes the necessary parts to install 500 clips- apart from the Spit Pulsa tool (sold separately). This tool uses gas nailing technology to secure the clip to a variety of substrates including: concrete, steel, composite steel decking, masonry and block work.
Copper "P" clips or steel ties can also be used to install FP200®. Plastic or Aluminium clips should not be used as the sole means of support as these will burn during a fire. Reference numbers are shown in our brochure.
Someone once told me the reason for metal cable ties on a fire alarm was to keep the cables out of firefighters' way, which begs the question: what about all the other cables?
Likewise using LSF cable to avoid noxious fumes from PVC should they burn in a fire, but running them in PVC conduit.
This is excactly the reason I was given at work.
I thought only FP200 but boss said all cables due to firefighting reason. Phoned ECA they said metal cable ties were not required for all cables, but were vague on when they should be used.
Enter UNG....
"Metal clips and cable ties must be used when fixing FP200, Firetuf etc to maintain it's integrity in fire unlike Pyro which can be clipped with nylon cable ties without a problem
If FP falls from it's fixings the cable can fail prematurely in a fire unlike Pyro which carries on working"
Very interesting ... is this from BS5839? and where does this firefighting reason come from?
