Discuss Metal-plated sockets and newly plastered walls in the UK Electrical Forum area at ElectriciansForums.net
Northgan
Quick question to electricians - I want to add metal-plated sockets to newly plastered walls.
The electrical wholesaler advised that newly plastered walls need 6 months to dry and thinks that the sockets will corrode if installed at the time 2nd fix. My builder and electrician don't think they will.
I am considering the BG Lexus sockets.
Wondering whether anyone has experience of metal sockets and newly plastered walls.
Thanks in advance!
Yes, the metal can tarnish with damp walls…
Some metal switches come with plastic frames that sit between wall and metal.
Remember to use the earth connection on the back of the switch.
Bulk buy a load of cheap white plastic switches and sockets until plaster is dry and decorating has been carried out so you dont have to worry about corrosion and fittings getting paint on them
Reply to Metal-plated sockets and newly plastered walls in the UK Electrical Forum area at ElectriciansForums.net
Electrical2Go - A Guide to Click Sockets: Which Is Right For You? Click Sockets Guide: Which is right for you? Click is a leading manufacturer...
My Champion generator is set up (according to the manual) as having a floating neutral. The plan was to run a 16A commando hook up cable from the...
Hi there, Just about to move into a house with 2 small kids and the wiring/electrics haven't been updated in years (hard to know as it's probate)...
  • Locked
5K
For emergency use, when there's a power outage, the current situation (no pun intended) is that I'm running a hook up cable from the 16A socket on...
