E
eagleeye
I have to do a job on friday and just want to make sure im right on something. At the moment the electric meter and cu is in the garage and the garage is being converted to a room. Garage door being blocked up so they are relocating the meter to an inset meter box in the new wall. i have to move the cu to the returning wall and down lower so need to extend all the cables to new position and run a 25mm 3 core SWA from new meter position to cu which is about 8 metres away. Question is, Do I need to fit a switch inline as the two are more than 3 metres away ? and the second question is, Will it be ok to join the T + E cables with JB's ? and could i join the rings together in the JB and use 4mm T + E to run to cu ?
