Discuss Meter tail upgrade what the hell in the UK Electrical Forum area at ElectriciansForums.net
That’s bad....cables not colour harmonised...I would have repositioned the meter to the left over the cut out and fitted the isolator to the right to save crossing the cables and then re-sealed everything.
Cut out looks like an early series 5 so probably 80A maximum load rating.
I've never called the MOP/DNO to come and pull a fuse, upgrade tails or upgrade main earthing conductor. I haven't got time for that.....If it needs doing, it just gets done as part of the job by me.
Lee, I know I'm sounding a bit of a dxxk but do you really think you should say that so casually. People listen to you on this site as you are experienced and knowledgeable.
"With knowledge comes great responsibility", man I'm cringing as I write this post, but also giggling!
I know you've specifically added 'by me', but some youngsters will ignore that bit just thinking it's fine to casually pull it.
Of course we pull the cutout at times as we simply have to but we still take some precautions.
1. Switch off all MCB's before pulling.
2. Put on electricians gloves.
3. Don't pull certain cutouts that could explode (cant remember the name of the substance, bakerlite, iron?).
4. Expect there are other precautions as well.
is that your demob suit from 1945?
Tsk, is that the best retort you can come up with......
I am the guy in the middle, I have a tan as I served in Egypt.......
Are you phissed?
Are you phissed?
Similar... I've done my back in so am on codeine, plus drinking strong coffee so feel a bit Euphoric and righteous until they wear off in an hour or 2, then I'll just feel moody!
Reply to Meter tail upgrade what the hell in the UK Electrical Forum area at ElectriciansForums.net
Hi all, So my factory needs more power, currently 100A/3p (70KVA) => 400A/3p (200KVA) UKPN wont upgrade existing supply and are insisting on new...
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hello again, Was looking at installing yet another dedicated consumer box for my EV charger off the henley blocks and i noticed that a meter...
Hi guys, I hope you're all doing ok in this heat!! I have recently carried out an EICR on a domestic property where it failed miserably. The...
6K
