Had to terminate 2 ends of an Micc cable when at college doing 2360.
we had to connect one end to a consumer unit the other to a Dp switch and it had to Ensure all testEd out ok. We even had to dress and tie it to a short length of tray.
if it went bang you had to do it all over again...
since then I have made off about 2 or 3 micc cables all in the same job fir a company doing work at an old church.
i had to borrow the tools off my dad as I honestly could never justify buying the tools for micc...
You could get away with just crimp tool!! I have many a time in an emergency.
One of my mum's friends used to work at BICC in Prescot in the 60's terminating lengths of Pyro that made up the octopus system wiring kits that were used in concrete high rise flats, she was on piece work and was paid 3d for every end might not sound much but they were fitting 20 - 30 ends an hour
The best I ever got to on site was 8 ends an hour on the small stuff my slowest was 16 ends over 2 days on a 12 and 10 hour shift there was a mix of sizes from 4H16 upto 4H35
I really enjoyed working with Pyro and have still all my tools in one of the many toolboxes that haven't seen the light of day for a while
I've seen most of types that were produced the biggest disaster was the all aluminium pyro followed by the AlCuMIC the aluminium sheath and copper conductors never found them nice to work with and even worse to rework
Then in the eighties we had the shrink on seals, the fire alarm system on one of Pilkingtons new sites was the first site to use them before they were released for sale, we got to find all problems pre release
Never heard it mentioned on any of the forums but does anybody remember the Pyro heat trace cable, when you placed the order you had to order the exact lengths you needed and it always came pre terminated
Yes remember it but never worked with it.
You can get away without any of the tools if you really need to, and I have in an emergency.
Strip it with side cutters, ring it with cable shears, fit the pot with grips (carefully) , crimp it with two pairs of grips (very carefully).
There's other things I've done in a difficult situation too, but I don't think they'll go down very well on the forum.
Better still ring the MI with a plumber's pipe cutter carefully, as for the grips Mole type gips would be preferable
Are we the only country to have used micc in the past ?
Can’t say I have seen it anywhere else in Europe...
As I say , I have never installed it in a new install.
Just some dry minor repairs when it’s been damaged or needed moving...
I don't have either of those tools in my tool bag normally, so can't turn to them for emergency repairs l.
