I must admit I have now tried the various brackets and got it wrong each time so I do not know what I was doing before.
Last time it worked but this time when I re opened the spreadsheet it was the same as D Skelton's version and the various brackets did not work.
Must have been asleep (or am asleep now):dozey:
I'm too set in my ways.
It makes deconstructing formula easier. For complex formula I tend to use hidden cells to calculate small sections then put them together.
Its how I’ve worked for 35 years. I started on Lotus 123, that was a bitch. Before that it was a spreadsheet, a 10' long roll of paper.
Me too, for complex formula this definitely works. It makes calculations easier to tweak this way!
For my accounting spreadsheet for example I have single cell formulae that are hundreds of characters long which can be a PITA to tweak when the need arises!
If that's a reply to this:
Unless I'm misreading BGB 543.1.3, don't you take the square root of I²t before dividing by k, not after?
How do others here interpret the formula in the BGB?
S is equal to... the square root of I²t... Which is then divided by k.
In other words, the square root of I²t is divided by k to get S.
k does not form part of the equation which is square rooted.
If it gets beyond this then I will break it up.
D34=SQRT(((B37*B37)+(B38*B38)+(B39*B39))-((B37*B38)+(B37*B39)+(B38*B39)))
D34=SQRT(G34-H34)
G34=((B37*B37)+(B38*B38)+(B39*B39))
H34=((B37*B38)+(B37*B39)+(B38*B39))
It all goes back to doing manual spreadsheets, some may find it confusing.
