Discuss mig/genny issue in the UK Electrical Forum area at ElectriciansForums.net
the pict
Mentor
A mate has a diesel genny 5 KVA MG 5000 1 LA seems to be the model, when using the mig it pulls the genny down to almost no power to weld,
he has tried a different genny and the welders ok, now how can I check the genny?, I suppose a applied load is the way to go but I really could do with some practical advice
Pict
My question is I suppose how can I check the genny output under load
Pict
You would need to load the generator with a high power load, something like a Load Bank, Carbon Pile, or for a home-made option 1kW radiant heater elements in parallel. With this test you should be able to confirm you have sufficient generator output to meet the Rule of Thumb. The reason extra generator capacity is required is because of the large losses caused by the high current switching transients and harmonics produced by the MIG welding action. You should be able to hire a Load Bank from most industrial Generator suppliers or Hire Companies.
Avtron LoadBank Portable Load Banks
http://www.hss.com/g/25305/Loadbanks.html
http://www.hillstone.co.uk/
Reply to mig/genny issue in the UK Electrical Forum area at ElectriciansForums.net
Iv been asked to wire a separator (portable to go to different farms and separate water from slurry) to a 3phase 40 kva generator. The separator...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
Hi all, I've been having some issues trying to fix a fluorescent light in the bathroom. Here's the steps I've taken so far after it suddenly...
Hi everyone. The owner of the business I work for along with myself have created a DIY inverter setup that is giving us some issues. We bought...
