Search the forum,
Discuss MK/BG Polarity sensitive in the UK Electrical Forum area at ElectriciansForums.net
J
joehat
As above are rcds that fit on duel rcd boards polarity sensitive? Eg can they be installed with the busbar on ten other side??
Sent from my iPhone using Tapatalk
use a RCD that is handed for the way you need .
MK have a lhs main isolator with RCD's following suit, BG have a rhs main isolator with RCD's following suit, you have both options with the brands you have mentioned, so why would you want to swap the bus-bar? use one or the other.
Reply to MK/BG Polarity sensitive in the UK Electrical Forum area at ElectriciansForums.net
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Just to be clear… I am going to do the correct thing here and pay for the correct parts…. I just wanted to start the discussion. My particular...
Hi everyone, I wondered if anyone could help me with something that has been niggling me please?! When a Solar PV feed in circuit is installed...
Hello, I was looking at installing a SPD into an existing split load RCD BG consumer unit. In the instructions for the SPD it states that it may...
