DurhamSparky
Well guys it seems as though Mr Electric has outshone him self again in the "I Can't Belive it" area
As you know a well know contractor i used to work for keeps making me laugh! his latest stunts are
1)
Call out to customer Property as the Fuse wire Kept Blowing on the Boiler Circuit. Not a problem just replace with new slice of 5a wire job a goodun!! POP! Ok Lets Try 15a... POP!.... HMMM bit of head scratching God dam electrics..... 30a Wire...! BANG!!! oh didums all the power has gone off!! the Electrician / Technician or in this case the OWNER of the Outfit managed to BLOW the MAIN SERVICE FUSE!!
what a chimp!!!
TAXI FOR MR PEACH!!!
2)
Customer fuse box has decided to smoulder and burn out...! (it happens every so often) Mr Electric on the scene ASAP! Diagnostic tools in hand and with a simple look condems the installation and informs customer new Fuse Box Required..! Customer insured via Home serve so no problem..! HOWEVER as its evening time and telly is on and tea needed when them things happen agreed to carry out work in morning!
what would you do in this situation
A) Disconnect Supply
B) Disconnect Supply and Remove Fuse and Replace Blank Holder
C) Leave as is and Walk away telling Customer he will have an Electrician first thing
answers on a post card but i guess you will all disagree with C).. NOT Mr Electric!!
