Discuss mould in bathroom in the UK Electrical Forum area at ElectriciansForums.net
Guy i used to work with, said he had this problem in his bathroom until he fitted a heater in there. Turns it on for a few minutes after showering to dry the moist air up
I don't think this can be understated, as has already been said. Many properties I have been to have had problems with damp and mould due to inadequate heating.
The extraction rate is 110m3/hr, as I am aware the bathrooms have been well cleaned with bleach and the doors are left open after showering. The main problem is two teenage daughters! Will a more powerful extractor do any good? How about a 4in dia vent in the door?
I would be careful where the extraction rate figure comes from. Usually the manufacturers figure on the box is for the fan in free-air, I've seen fans without ducting that are 25% short of the stated air movement figures as soon as you clip the cover on. If there's a decent length of duct installed I would actually take a velocity measurement at the fan or the discharge louvre and work out the volume from that. I'm still thinking it's probably a combination of undersized fan, and maybe poor provision for make-up air.
I would also actually run the shower and see how much it mists, we had a mildew problem in one of our ensuite bathrooms that was caused by a badly designed shower head causing fine mist that left the whole room drenched.
Evening Mike the Sparky. I have some rentals on my books, agreed with all previous threads.
Private tenants are always struggling and cannot have the heat on/up.
Windows are never opened. You've got to do your best on extraction.
- - - Updated - - -
What he said.
It is the actual extract that you are achieving that is the key not the fan rating. 10 air changes/hour minimum I would recommend. This fan , if acieving the stated extract rate is still only achieving 7 ac/hr. After ductwork losses and struggling for makeup air probably a lot less.
Also air movement should be considered. In this case all that is practical is to look at fan extract position in relation to the make up air from (I assume) the bottom of the door.
Yep is the fan big enough and how long is the duct if its 1.5m or longer then you need centrifugal over axial also the fans take air out of the room is there a vent for fresh air to come in or a vent in the door is some old houses you could get Top Cats wallet in the space under the door.
One last point and please dont tell me I am racist I do repairs in rental properties and some of the tenants from the Indian sub continent have a LOT of bother with damp as the seem to do a lot of steam cooking throughout the day plus they will not and I mean not open a window or switch a fan on as it is toooooo cold in this country and tooooo expensive for electricity I have tried to explain that it is a culture problem and that they need to let the property breathe but to no avial
As oldtimer has mentioned one of the main problems with ducted extracts, is the length of duct the fan is expected push the humid air through. Add a couple or more bends, especially any tight'ish bends and your problems are magnified no end!!!
yep...straight runs (where possible) for ducts.....you can have a max of two 45* bends for 100MM ducting...i think thats what it is anyway
I had gone through the post. Many equipments are available for cleaning the mould in bathroom,actually It is one of the severe problem for many of them, but there is a best solution is there. Generally. water a little bleach down & spray it, like our bathroom needs more ventilation. Please produce some more attachments about the topic for view detail information.
Reply to mould in bathroom in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Electrical2Go - Beginners Guide to Positive Input Ventilation (PIV) Units: A Solution to Indoor Air Quality Woes A guide to Positive Input...
I have a bathroom extractor fan to replace. It is the type that has the light in the middle of it as in the picture below.. They all seem to be...
Latest fun on the job from hell. I need to replace 2 x Vortice Ariett T ceiling mounted centrifugal fans, but struggling. I could buy...
O
So, got a client in a concrete structured block of flats - 2 bathrooms with "wall to wall" windows so nowhere to put extractor fans. Fortunately...
