Discuss Mounting equipment in the Electrical Forum area at ElectriciansForums.net
B
bathroomboy
Got a job coming up where I intend to split tails, henly block and shower unit, existing cu is mounted on breeze block wall in the garage, will I be ok mounting the henly block etc on the breezeblock or will I have to mount it on a board and if so what kind of board, does it have to be of special material. Thanks
I'd mount in on a board.Why are you running the shower off a henley block:confused:
Dont need anything what I would do is copy what has already been done with the other cu gives a much neater finish to the overall job
Chris
Reply to Mounting equipment in the Electrical Forum area at ElectriciansForums.net
