Drinky
Hello,
I have a 1930,s house I am renovating and I would like to get the CU, meter and incoming 100A fuse all moved from their current position on an internal wall at bottom of stairway which is only used to support it, 90 degrees to a wall next to it. No wiring needs to be extended as plenty there, if anything the tails might be shortened once all moved. Need a new metal CU fitting at same time. The main incoming cable just needs moving about 300 mm no extension needed can be done live. Do I need to get the electricity supplier involved as well as a electrician? And any idea how much all this should cost?
Thanks a lot,
Sam
Thanks a lot,
Sam
