For those of you who won't be able to sleep tonight without knowing what the problem was, it turns out the conservatory light was full of water as the wind had been blowing the rain up the roof, I assume the light is on a switched fuse spur off the downstairs ring.
Thankyou all for your replies, and TGIF.
Down2earth.
So, presumably, it was the RCD that was tripping and not the MCB?
Water doesn't have a sufficiently low resistance to allow the kind of fault current that will trip the magnetic side of an MCB.
Hi,
Depends how close the wires are, I have seen one kettle lead with a lot of tracking on it between L+N and it blew out of the kettle with a loud bang and took out the 13A plug fuse.
UKmeterman
This thread has made me chuckle.:sunny:
It's always nice to see a thread update letting everyone know what the issue turned out to be. It would be nice if it happened more often:)
