M
Mr Mark Sparks
here is a picture IMG00140-20101108-1133.jpg in about an hour i will post the answer
what have i done wrong?:confused:
You haven't tucked yer cables in, the plasterer will be well upset and chop em off!!!!
haven't split the ring. broke the budget with the brassware instead of grommets:p used old colour cable. notched a vital supporting battern:D sockets aren't facing north, forgot to plasterboard it once you were done, I could go on but it may get embarrassing ;). I do like the brass though nice touch
pennywise i cant belive with all those guesses you didnt say..........
used 3core in the ring by mistake
I did say I could go on;) no genuinely didn't spot that whoops!. Well a 2way socket may be the future you never know :D
I would have said it was something to do with the cable route - they just seem to whaft off to the left of the picture in the general direction of out of any safe zones.
Brass bushes!!!
My word, posh job eh?
Grommets not good enough for ya then?
:D
it is a high spec job nobody said i had to use the bushes but they are much better and the client wants the best job poss,
hence lsf t&e etc
the do run away a bit but they are in the gap between the stud and the wall
40mm thermal plaster board and a 3" stud away from the surface.
Mr Mark Sparks,
Mr Mark Sparks,
