Discuss Need some advice on my Brothers wiring in the UK Electrical Forum area at ElectriciansForums.net
118v may be 2 lights wired in series.
old school cowboy work, looks quite neat for "tape and chocbloc" type.
modern one will join the cables in the switch and drop one cable into the light fitting.
at least is quite neatly taped, sometimes you find them uninsulated and buried in messy lath ceiling...
I can't give you a picture but it was a going to a bar light with 4 spot lights along the bar with gu10 leds bulbs. The joint under the tape had 5 wires going in to the single choc block.
I would say it fails to comply to regulation 526.5 but I'm not a qualified electrician.
Modern what - Cowboy ? I use that method all the time !:90::biggrin5:
Reply to Need some advice on my Brothers wiring in the UK Electrical Forum area at ElectriciansForums.net
