Discuss Need some help connecting an oil combo boiler in the UK Electrical Forum area at ElectriciansForums.net
First time connecting an oil combo boiler. I have a Honeywell wireless room stat and 2 channel programmer. Could anyone with boiler experience give me some guidance please?
Upload the image directly to the thread: The most awesome images on the Internet - https://Upload the image directly to the thread.com/a/j1ZuV
Just noticed the connections in the 1st post. The the hot water side of the two Channel programmer is for timing the pre heat of the hot water. It's just an extra function that keeps the water hot when timed so when a hot tap is opened the hot water doesn't take ages to come through. You would just time the hot water pre heat on the timer for when hot water is at its highest demand...morning, lunch time and evening etc. Live out on boiler connects to L of programmer and thermostat, CH on connects to A, B connects to LR with radiator symbol, HW on connects to LR with tap symbol, neutrals and earths terminated appropriately.
Reply to Need some help connecting an oil combo boiler in the UK Electrical Forum area at ElectriciansForums.net
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hi all Mate of mine is getting a new utility room fitted, the kitchen fitting company have brought in their electricians for first fix and to be...
A nice easy one for all the (many) people that are cleverer than me 🙂. Could you please point me in the direction of a wiring diagram for a...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
