- Reaction score
- 0
Ive searched quite a bit for this problem but cant find anyone else having a similar experience. Installed a 3rd Gen Nest on a Due-tec Combi HE a Range boiler. It had no existing thermostat on it. It was controlled by a Multifit Integral 24 Hour Electro-Mechanical timer.
Everything works great, no problems installing it, no problems with anything. I can turn the boiler on and off from the home wifi and away from the house. The problem starts after I leave it for a day. When i come back to turning the boiler on it wont turn on. I can hear the Nest link clicking as if its trying but the boiler isnt coming on. If I turn the boiler on via the Timer we are up and running again and everything works.
I've tried turning the timer to manual and deleting its existing timer settings thinking its clashing with the Nest, still not working.
I thought maybe the hot water is the problem, having a shower on the morning seems to be the only activity that the boiler sees. Doesn't make a difference. Ive tried the hot water multiple times and Nest works. I cant be sure but it just doesn't want to work after about 12 hours.
I've included all my wiring in the images below along with the boiler diagrams. I feel its something to do with the existing timer cutting the power to the nest but cant be sure.
Anyone had similar problems and have any suggestions?
Dropbox - Boiler - Simplify your life - https://www.dropbox.com/sh/duzrs7rhn3qk59g/AADltsW4I_veMqXKmmpInMuBa?dl=0
Gav
Gav
