new build tips
one thing i forgot to ask- consumer unit location?
think the meter is going outside front of house in a meter cupboard
consumer unit ok to go understairs still? or stick it somewhere else at 1350-1450mm level?
OP can I just ask, what knowledge and experience have you of domestic work (not that its a dark art)? The reason I ask, is you profile doesn't state your skills base, and your avatar suggest you fit alarms etc. Shoot me down in flames if you want.
few full re-wires under my belt for myself at the age of 23- not bad going
and about 9months of subbying- 1st and 2nd fixing new build flats
and then before this around 5.5years in social housing doing the usual cr*p!
so where do i forward my cv to you? lol
all jokes aside- i am asking questions- because i myself havn't taken on a new build job yet...
rewires on existing don't usually have a building inspector if no building alterations were done- so socket heights, fan requirements, c/u locations, smoke alarms are recommendations etc i know- but not requirements
however NEW BUILDS- i know the above are required -hence me brushing up on it.
the new build work I have done (subbying- not for my own company)- you just follow the drawing, job done, get paid
now its for my own name- I want to get it right.......
Can't knock you for trying to better yourself, but you haven't answered my question of qualification. I didn't ask for your CV?
I'd put it somewhere that doesn't require a distribution circuit with switch fuse from meter to CU.
Not sure I agree with that statement...
I wouldn't put it under the stairs. Is there a cupboard you can put it in?
I spotted that too. some more research by the OP might be in order. I fully recommend JCE downloads and reads all of the current approved documents.
on a re-wire (so existing build)- or even a extension to a exisitng build- are you not allowed to match current socket height ie not 450mm (part m)
on a re-wire (not new build or extension) -if customer doesnt want to pay- do you have to put smoke/heats in (part b)
on a re-wire (not new build or extension)- do you have to put fans in bathrooms, wc, utilities, kitchens (part f)
no no no!
yes me and you both know you should- but its not a NEW BUILD!- no building inspector is going to inspect it
as long 'as it left in no less of a satisfactory condition than how it was' and complies to 7671
any ways- you guys are slightly going off track!
I am saying I will be doing these things- I am just trying to brush up on things for new build rather than existing
no no no!
I'll retract my post #41 as I thought you were referring to new builds. Sorry, did not read your post properly.
I think the questions you've asked are reasonable for someone who hasn't done a new build before and yes you could of researched and read all the relevant documents but easier to ask other electricians on here who do have experience with new builds................ At the end of the day this is what the forums here for so electricians can discuss such things and its not like your constantly asking daft questions and just looking for a little clarification. Probably best you update your profile with your quals but don't feel like you have to justify yourself.
