S
Spudnik
How would you connect the RCBO to the RCD main switch?
Why can't I just have an RCBO on the lights straight from the main switch and a rcd controlling all the other circuits?
Any views welcome
Martin
I had ordered a an 8 way cu and intended using and rcd 80a switch to control the other ways in the unit other than lighting. The inputs for the rcbo for the lighting unit would be connected to the main switch using a split board kit and the output L+N to the lighting radial at the rcbo terminals.
Sound right? I know not quite. that is why I sent it back to electrifix. I need to get the job done.
But I think it can be done. However, it is more expensive than the 17th cu they do so there is no point.
What do you think?
