A
atm84
I have had a number of dealings with DNO's.
First you will need to fill out an application form and they will want to know you demand (after diversity) and they won't help you on this one.
You can request a budget estimate which you should get back in 10-15 days normally but its a budget and they will likely just pluck a figure out of the air.
I suggest you ask for a firm quotation which takes longer (think approx 28 days) but will involve a survey.
They will then put a proposal together, telling you what needs to be done and the cost. Youse need to pay a design fee up front before you even get a quote but you may get away without.
Next after you have received the quote and are happy you have to pay in full before they do any work.
I suggest you get a quote from the local DNO and then go to an independent DNO for a second quote. And independent DNO will generally be 10-20% cheaper.
