Discuss No electric in my garage in the UK Electrical Forum area at ElectriciansForums.net
G
gimpchop
Hi i had my garage converted in to a office about 5 years ago. Today i went out to my garage and there is no electric. I have checked the mcbs in the garage and they are all in the correc possitions and allso the main mcbs in the house and all are in the correct positions can any one point me in the right direction in to trouble shooting it pls.
Have you checked the RCDs? try resetting the cbs sometimes they can fail in the ON position
Hi dont think there is a fuse just a rcd in the main fuse box in my house leading to a fuse box in the garage conversation with rcd for lights, sockets, water heaterand the main cut all rcd all seem in tacked and in the on position. I have switched al rcds on and off a few times with no effect.
If there is no fuse to be changed and you've exercised the MCBs and RCDs and there's still no power, it's time to call your local friendly Electrician who will have the tools, knowledge and experience to quickly find the problem. And hopefully the fix won't take long either ... haven't been digging in the garden nearby have you ? :)
Hi rhanks for the reply. Yes there is a fused spure from my main fusebox in the house but it hasnt tripped the mcb in there either.
Might seem a daft question, but that z-spa on for all those hours would be quite a heavy load, you haven't burnt out a main L or N in the Garage CU have you, due to a loose connection?
Hi done a little testing. With a voltage tester there dont seem to be any power from the mcb on the main fuse board. Ive teaced the cable from fhe fuse board to a join where it comes from the house to the armored cable and there is no power there either.
Join what sort of joint? a wacky one?
Reply to No electric in my garage in the UK Electrical Forum area at ElectriciansForums.net
I have found out that my electricity supply in my external garage is wrongly connected to my neighbours electricity unit in their house and their...
Hi there, long time lurker, first time poster here. Straight down to it.. A friend asked me to add some sockets and additional lights to a small...
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
