L
lofty84
I changed my parents consumer unit to a new 17th eddition MK one a little while ago. Everything went well and when I turned it all back on there was no problems with any of the rcd tripping so it looked like everything was good and I knew what Iw as doing. Today though I was just being nosey and trying to work out this 2 way lighting mylarkey as its always confussed me so much so I always let someone else do it while I did something else. well anyway I turn of the mcb which I running the downstairs lights and on the right hand side rcd. the upstairs is on the left as you do. well having turned it off and watching the lights go out I set about undoing everything (taking a picture of it before of course) to see if I could work it all out (which I couldnt) and low and behold I got a bloddy shock. Im gonna sound a right cowboy but most of my tools are in my buddys van so I didnt have me voltage/continuity tester to double check and just plouged in as the lights had gone of but as I say I got a shock. Im thinking there must have been a borrowed neautral or something from the lights upstairs somewhere but Im not sure. I didnt want to turn the upstairs light breaker of and then touch it again to find out and obviously I didnt have my tester to see, so I just turnt everything of at the main switch terminated everything back together as per the photo and turned it back on where it all works as before.
Any ideas what is going on and am I right about it being down to a shared neautral somewhere. I will set about finding it if it is but I wont be that till i buy a mft
cheers
cheers
