Lofty84
Start at the begining. What does this 2g switch in the dining room do? Which light does each side of the switch operate?
Sorry Tony I missed this thanks for showing an interest. This is what happened mate
Basically I start a new job on Monday Im not sure how I got it but I did, so having had to go back into a office I thought I would try and work out this 2 way lighting mylarkey but half an hour later and after fraing what I saw in the switch at the bottom of the stairs and the top I decide I would move on.
As I say having got no where with that I thought Id have a look at the lighting in the dinning room.
In the dinning room there is two lights one on the left and one on the right really. when i flick the left switch the left light came on and when I flicked the right switch the right hand light turned on. right I thought I know what Ill do Ill rewire this so that when you flick the left switch the right hand light came on and when you flicked the rights hand switch the left light came on. I dont know why I wanted to do this maybee a bit of a confidence booster which sounds silly but I wanted to do it anyway.
so with both ligths switched on I went back the the board and flicked of the breaker which does the downstairs lighting and off they turnt. excellent. so i pull out my screwdriver and undo the 2 screws and set about undoing the termiations. out comes the cable in the left whcih had the red (live) going into the common and black (neautral aka switchline) I know that correct but confirmation would be good going into the 1 way hole, there is also a hole with 2 way above it but this has been left emty. I do the same for the right hand side and it is wired exactly the same as the left. anyway as i go to rewire it and touch the live cable (not sure which one) I got a shock
- - - Updated - - -
Start at the begining. What does this 2g switch in the dining room do? Which light does each side of the switch operate?[/QUOTE]
