Discuss not sure on board type in the Australia area at ElectriciansForums.net
S
sparke
Hi all , passed my elecsa assesment a week ago and im ready to go .
been to a couple of jobs recently where the consumer unit was not up to what was installed in the dwelling at present.customer is willing to up date but the problem is a majority of these insallations have only 2 or 3 circs typical local council for you back in the day, eg lights on 1 all sockets on another including heating .how do i fit this to a 17th edition board do i have to take up floors ,go into loft spaces an seperate circs back to new consumer to get it to comply or do i put in a none 17th ed board that is rcd protected ? not sure..:confused:
Did you say you passed your Elecsa assessment?
If this is true I am very alarmed that you are asking these questions, and am even more worried that Elecsa is paasing people with very little knowledge as is evident from your question.
Or is this a late April Fools joke?
you need to fit a 17th board and do your best with the circuits you have got, lights 1 side, sockets the other will be fine,
you only have to deal with the circs that are there not create new ones. cheers
Sorry no late April fool . Not asking you how put in fuse board or what type to insall . wanted to know how far to go if we are useing 17th edition regs and house doent comply did i need to ajust existing to do so. Advise was what i was after not comments about my knowledge ,
get over your self!!!!!
Hi sparke
I would put a csu with a 100Amp double pole switch as main switch and all of the circuits on rcbo's that will give you individual rcd coverage on lights and sockets so if you loose one you dont loose the ohters. If there are only 3-4 circuits it wont run that much more than a so called '17th edition board' or even cheaper if you source cheap enough rcbo's.
good luck
Yes, rather nasty there from sivoodoo, there are a lot of silly questions that most people would think easy and I am sure we all have them, perhaps we should try to help these guys out.
Exactley, Im the same, you dont get no where if you dont ask. Its better to ask and do things correctly rather than not asking and making a mess of it.
I agree, you dont get anywhere if you dont ask, but i personally feel the question being asked here is pretty basic stuff!
I would be worried if I was a customer hearing this.
Everything you do in a domestic property should be done to the 17th Ed.
I do hope you are going to test for insulation and continuity before you swap over the CU, otherwise you may discover more problems.
You will also have to upgrade the meter tails if you are installing a larger mainswitch.
Good luck.
Reply to not sure on board type in the Australia area at ElectriciansForums.net
Here we go again, another job that has had a council inspection, different council to last time but still perplexing. The problem with these jobs...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Hello, I have a Clipsal consumer unit with two "ways" unused and blanked off and potentially a third available as the Proteus Geyer B16 MCB is...
4K
