T
thomas-1981
http://www.esc.org.uk/fileadmin/use...y/best_practice/BestPracticeGuide4-Locked.pdf Try this, maybe useful.
arty:
arty:Naturally assume that customer will always take lead out through same route, perhaps this ought to be written on certificate to cover ones own.but what's to stop him plugging his lead into another socket that's not RCD protected.?
sorry if the party thing upset you it was purely for the stick i got yesterday.
the regs are full of opinions as i stated in an earlier post but i have also said that this was my opinion from reading the regs and guidelines. others will differ depending on each individual circumstance when doing a EICR.
AS for what happens if he plugs his lead into another socket that argument flows both ways, what if he uses a lead that is not rcd protected.
So this then makes a mockery of the whole code c2 then? Talk about doing something for the sake of it! Why not just go the whole hog and change every socket that is within 3m of a door or window, otherwise the next inspecting electrician may follow the Nic advice and change another socket because they found the customer using a different socket to the one you changed! This sort of carry on gives us a bad name.
Eitget solve the problem completely or leave alone.
yep thats the one they quoted from.
