Discuss One of those days in the UK Electrical Forum area at ElectriciansForums.net
As a last resort maybe change the switch for one that has line in at the top, like this Lewden fused switch for example
I also thought that and I like the idea but you can't terminate into the side of those so it might not work for OP.
Also the load L connects top left, but it's probably long enough.
Are the earth terminals 32mm on these?
It's hateful when things like that happen. It's the sinking feeling when you see it afterwards. We've all been there
Exactly! But for the grace of God go I...
Recently I realised I had punched out the top hole on a rotary isolator's case. Thankfully I found I could just remove the switch mechanism and turn it over. But it still annoys me one is in right and the other is almost the same but not quite :(
Yea I actually didn’t see it on site.. went to bed & it just came into my mind did I actually connect it that way…looked @ the pics in the morning & there it was….shocker?
Reply to One of those days in the UK Electrical Forum area at ElectriciansForums.net
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
So I just started out recently and I’m struggling with what to price myself at. It’s worth noting I live in the east London area and I’m looking...
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
Ok. Can you cut a ring in half, add junction box, then run a spur off it? I thought it had to be from a socket? Mate of mine wanted me to see if...
