Discuss Outdoor Bluetooth/Wi-fi switch in the UK Electrical Forum area at ElectriciansForums.net
Morning,
I’ve got a customer who really wants to have two wall lights mounted on their garage wall, easy peasy. She wants to switch the lights on via an exterior switch still simples. But she also wants to be able to switch the lights on from her phone, I’m imagining it’s pretty straight forward and it’s something I’ve done before but the switch has always been indoors. Can anyone recommend a good exterior mounted 1g switch which is Wi-fi compatible? Alternatively I suppose it could be a standard exterior switch but the lights could be Wi-fi compatible if so any good manufacturers/websites to hit.
Not aware of a wi-fi switch (that doesn't require a separate hub) that is waterproof, but it seems to me you would need a two way arrangement, using a conventional 2-way outside switch connected to a 2-way indoor wi-fi module or switch. If you had just a wi-fi compatible bulb, it could only respond to the phone if the outside switch is on!
How about a quinetic switch module indoors https://www.quinetic.co.uk/products/wifi-receiver/
and a Quinetic outdoor switch (IP67) https://www.tlc-direct.co.uk/Produc...MIxNuS8N6W7QIVk2DmCh3-7gzkEAQYBSABEgJZbvD_BwE
Reply to Outdoor Bluetooth/Wi-fi switch in the UK Electrical Forum area at ElectriciansForums.net
Hi. I want to replace my traditional light switch for a smart Wi-Fi switch, but my current switch has 3 cables, COM, LOOP and 1WAY. Where should I...
Autumn is now here, it's that time of year where the clocks go back and lighting control moves forward. A time when UK customers with gardens want...
We wanted to hang festoon lights in the garden and have them switched from inside the house and my builder (4 years ago) installed a '10A 3 Pin...
4K
Good morning hope everyone is staying safe. I have a question for some of the more experienced sparks, I have a client that wants her outdoor...
4K
Hi everyone, I want to install a wifi switch in my room but the problem is I am not very informed in electrical wiring subject so would appreciate...
