dogbob
32
NH
United States of America
I'm in USA, not an electrician. My home Rainbird model ESP-ME3 irrigation timer comes with a 115VAC cord having a right-angle plug. The manual says to either plug it into an outlet or remove the cord and hardwire it to power. They don't specify details on hard wiring. I guess that varies with situation.
I have a weather-rated duplex outlet near the timer with a flip translucent cover. The installer plugged the timer into that outlet. With the timer plugged into the outlet, the right-angle plug covers the second outlet. This is a problem because I sometimes need that second outlet.
Alternative #1: Replace the supplied power cord with an exterior-rated power cord having a straight plug. Or cut off the right-angle plug and replace it with a straight plug that isn't too long. This would be easiest. But it seems sloppy to have a floppy power cord permanently connected to the side of the house.
Alternative #2: Hardwire UF without conduit or THWN in conduit between the timer and the outlet.
Alternative #3: Run UF or THWN/conduit to the load center using an existing or new circuit breaker.
What do you suggest?
Thank you.
Thank you.
If it was me I would just cut the plug off and install a new one. Make sure that you pay attention to the plug and keep the polarity the same as the old one.
dogbob
NH
Outdoor irrigation timer wiring
USA Electrical Forum
Thread Tags
Tags Tags
wiring
dogbob,
Megawatt,
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
