Discuss outside lights in the Industrial Electricians' Talk area at ElectriciansForums.net
B
bahco
now then
i need to install 2 500w pir floodlights i know that using twin & earth is a big no no so i need a bit of advice
basically the cable will come out of the wall straight into a stuffing gland, i no that artic flex does the job but to my knowlede they only did it in blue and yellow and i need white really.
so consedering there will only be a few inches of cable on show is it ok to use normal white flex? or does anybody know of a better way?
thanks in advance
matt
Reply to outside lights in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Am fitting a new pir led floodlight . The exsisting light is connected to 4 core round flexible cable, core colours green/yellow, blue, brown...
I have a Security Light on my patio and until recently it worked fine. It stopped working and I couldn't decide if it was the LED Floodlight or...
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
