Hello! I need help to get my oven safely functioning before Thanksgiving!
I bought and replaced the top burner element in our oven.
BUT, when I detached one of the wires from the old element, it retracted back behind the wall of the oven. While fishing the wire out through the little hole and pulling it back into the oven, I ended up stripping a bit of the insulation off the end of that wire. So, when I turned the oven on, it sparked and created a flash burn where the wire was exposed.
**How can I safely (and non-toxically) re-coat that little bit at the end of the wire so that the top burner can be used?
(I thought about electrical tape or even paint on electric insulator tape, but those will just melt at high oven heat and will also release toxic fumes/chemicals that you don't want your food exposed to).
Any ideas??
Thanks!
Any ideas??
Thanks!
