Darkwood
I understand where your initial argument/debate is generated from but reg 433.1 actually states the design of the circuit is unlikely to have a small overload for a long period... if you are in the senerio you are debating about then the circuit has been designed wrong and you are in breach of the regs anyway... the senerio you are using as you defense should not occur for a long duration, short duration can be acceptable and is common on some old ring mains and even if you had a cable for example rated at 36 amp pulling say 45amps its been allowed for by the research into the structure and tolerances of the cables we use.
Ive seen over my many yrs cables drawing 15+ amps past their rating for yrs before ive come across them and other than been discoloured slightly they are still holding integrity (well just) but these conditions were caused because copper wire had been fitted in place of fuse wire thus overload wasn't detected...yes they ran quite warm but didn't fall apart or combust.
