G
Guest55
Thank God, A mod with a Brain
so youre suggesting our other mods are brainless ?
banstick for mike !
Yes but the calculations and adaptions to new products is all based on trial, error and scientific calcs of decades gone.... do you have a copy of the reg's i will ask you one more time to read 433.1.1(iii) there is a value there crucial to correcting your error... if you dont have a copy of the regs i question your competence as onsite guides are only for fast retrieval of the most common looked up areas.
For Mr Cockburn.
banstick for mike !
rrr:You got a copy of the regs on your phone? If so how did you do it?
Buy them from the IET just over £200 for regs plus all guidance notes the osg and the installation design guide. Have them on PC phone and iPad.
I propose an experiment for Mr C, create a radial using 4mmsq, put a load of sockets on it, stick it on 40amp breaker and crank up the load to 40amps.
Make sure your connections are good and report back.
Think you might find it does not burst into flames, in fact i would be interested in the cable temp readings you can get.
