- Reaction score
- 4,325
I discovered while visiting an elderly neighbour she was using a 2 socket 2m long extension lead wired with 1mm2 PVC 3 core (- both a Duraplug double socket and 13 amp and 10 amp fused plug) to supply her ironing board in her lean to extension on which she had plugged a 2.2kW steam press and 2.4kW steam iron. She had been using this arrangement for a year. No visible (internal or external) problems to any of the electrical components. Extension supplied and wired by a friend who was a retired electrician. Even a label near plug to only fit a 10 amp fuse. Extension originally used for lady's sewing machine and a lamp but then change of use for the ironing and pressing arrangement now.
Thoughts invited on whether to continue with this arrangement.
