( DIY; qualified to PAT. ) We (a charity: Besom in Runnymede) were given a portable deLonghi oven EO12012. It failed its insulation test. I suspect that one of its elements is leaking. I opened it up and the wiring goes:
live --> timer --> element selector switch --> upper or lower element --> temperature control ( TC) --> neutral
So the Tc interrupts neutral, not live. Please: am I right that this is a fault that I must rectify (as well as the insulation) before I can pass this oven? Thank you for advice.
Hi mark641,
Not sure what the regs are like in your neck of the woods (I'm in Australia), but under AS/NZS 3760:2022, a few things are very clear:
A test and tag technician must not open or dismantle any equipment under test — that’s outside the legal role unless you're also a licensed electrician, and it can be unsafe.
If an appliance fails the insulation resistance test, and this isn’t clearly a false fail (e.g. due to moisture in heating elements), then it must be withdrawn from service and referred for repair by a competent person.
Appreciate you raising this — a common misconception among those new to test and tag is thinking they’re there to fix or repair appliances. They're not.
If you're unsure, here’s what I’d recommend:
1. Don’t interfere with internal wiring or switch arrangements — that’s a job for someone qualified to do repairs.
2. If you have access to the manufacturer’s instructions, or can contact them, check if there’s a known reason for the failure (e.g. damp storage affecting IR).
3. Otherwise, tag it out of service and recommend inspection by a licensed technician or authorised repairer.
4. Some testers here may try a leakage test as an alternative (especially with ovens), but only if the unit has been fully dried or preheated (e.g. 100 °C for 1–2 hours).
I’ll be raising this example in my class next week during our discussion on test failures and escalation protocols.
Cheers.
