Discuss Polestar and Loadstar in the UK Electrical Forum area at ElectriciansForums.net
Pretty sure they're identical. I believe the Polestar MCBs are rated at 16kA whereas the Loadstar MCBs are 6 or 10kA.
Starbreaker MCBs have the tab on the back which clips into the DBs built in busbar.
Actually I am considering the old Polestar range and looking at the new style it is hard to say.
Yeah, the old Type 2/Type 3 Polestar range were definitely wider but the more recent B Curve/C Curve Polestar i think may be the same width as the Loadstar range. Could still be wrong though!
I jumped the gun a bit quick and immediately thought of the old range. Must admit they look identical apart from the ka rating. I would still stick with the correct range though.
Check the din rail connection the pole star mcbs have 2 different sizes one fits a single phase board the other fits a 3 phase board as it had a larger terminal where it fits onto the bus bar.
Reply to Polestar and Loadstar in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I needed to replace an MCB for an electric shower with a different rating, it's an older Loadstar consumer unit, and crabtree told me word...
I'm working off a photo and haven't been there yet - I think these are Crabtree Polestar breakers in this old 3 phase board? Do the slightly newer...
I have a job which is needing a new CU. What would the general view about a new Crabtree loadstar SPN 125A board being used as a domestic consumer...
Does anyone know offhand which SP MCBs are compatible with Crabtree Powerstar 3Ph boards? I need to take a 60a supply from this board but I can...
The breaker pictured trips with nothing plugged into the circuit. It is able to be reset and stays reset for several days, but trips again. When...
