P
paulperro
Hi, I'd really appreciate a second opinion. We are having an extractor fan installed in the bathroom. The bathroom is approx 12ft by 6ft6" (3m by 2m). Due to limited wall space an electrician has suggested we should locate the fan in the corner diagonally opposite the shower cubicle (which is the main source of steam). The reason for installing a fan is the steam from the shower condensates on the windows and causes mould growth in the window recesses. The windows are on the same wall as the fan would be situated and are both be closer to the shower than where the fan would be. My question is will the fan be effective or will the steam still gravitate to the windows causing mould growth given that the fan is in the far corner in relation to the shower? Not sure what the make of the fan will be.
Fans won't irradicate all steam that's present, Fan encourage air changes and the movement of air flow, it will help and will remove wet particles and dampness n the air
you have the same bathroom as me by the sounds of it and my fan is in the position you are describing it will help but u will still get some condensation on the windows , the ideal place would be on the ceiling vented outside but no always possible
I'd rather go for a ceiling diffuser above the shower and a fan in-line in the ducting. In a small en-suite type bathroom with a shower I'd be aiming for 15-20 air changes per hour. You may need a condensate drain as well to prevent water build-up in the duct and dripping through the diffuser. As Murdoch suggested make-up air is important so either a louvre in the bathroom door or some kind of gap.
Sorry, obvious when your using the bathroom but wouldn't you keep it slightly open when the bathrooms not in use?
