I am not a qualified electrician. I recently became a director of the freeholding company of a block of 24 flats in London. The company is owned by the leaseholders. The flats were built in the 1950s, concrete and brick construction. As part of getting familiar with the property and the issues being faced I was shown a distribution board in the basement which has fuses in it. I understand this board is where the supply comes in from UKPN, and it is divided up into separate cables that go to the flats, with one fuse per flat. There is a picture of the box attached.
Compare Home Electronics
Not being an expert in any way, I was rather surprised by the worn-out appearance of the wiring in the board. There are three things that worried me:
1 - The cables at the back look like they are in a bad way
2 - Where there are some empty fuse holders, it looks like there are little white woven blankets. Is that asbestos? I was not previously aware that there is any asbestos in the building.
3 - Some of the fuses seem to have brown staining around the holes. Might that be a sign of either corrosion of the connections or even over-heating. It looks alarming to me.
Could anyone advise as to whether there might be some major problems lurking here that need urgent attention?
Thank you very much
John
PS Help! I can't attach the photo of the distribution box. I have tried .jpg and .png versions, reduced the size to 400k or so, but it still will not work. Its appears to upload when I click on "Attach Files" but there's nothing there in the posting.
Thank you very much
John
