J
jarrv
Hi all,
I have a question that i hope someone could shed a little light on.
Last night / early there was a short power outage in my house, after a few minutes the power was restored.
However an hour or so later the same happened and again a further e or 4 times.
When the power did come back on it seemed very weak for want of a better phrase, the lights were very dim as if they were running on a battery or had been dimmed.
I unplugged all the devices around the house as a precaution, and checked all the trip switches/fuses and there was no sign of charring or any other failure (not tested them).
The power failed again just before i left for work, I have called Northern Powergrid and spoken to CS who confirmed there was a local power outage (Leeds, LS15) but it was fixed around 08:30 when i had left for work.
I will check if the power is on when i get home around 3pm, if it isn’t what is my best course of action?
Replace all the trip switches? (there are 6, 4*30a, 1*5a, 1*15a)
They appear to be the “30A Mini Trips Type B” available at wickes around £10 each.
Call an electrician to investigate?
Is it possible the whole unit has been damaged by the power outage?
Thank you for any help
Mark.
Mark.
