P
ParaJack
Hi, I've just been to both Wickes and Screwfix to get a replacement 1500mm x 36mm fluorescent tube. However, both places said that they haven't seen the 36mm tubes for a long time! Screwfix suggested to try the 26 mm tube in the fitting and see if it works as the pins are exactly the same width apart.
I put the slimmer tube into the fitting and it turned on straight away, so my question is: Is it 100% safe to use a 26mm diameter fluorescent tube in a 36mm holder?
May be a daft question, but I thought I'd make sure!
This is the new tube Sylvania Luxline Plus Triphosphor Fluorescent Tube T8 5200Lm 58W | Screwfix.com
The old tube just says Sylvania F 65/80 W/W
Thanks in advance
Thanks in advance
