Like tel says clamp the earth, and pull fuses or switch mcb's to find the leaky circuit
almost all wylex and crabtree rcbo's I have ever tested trip between 19 and 23ma even when new
You need to perform a core balance test to establish the leakage, using a milli ohm clamp meter. If you clamped the earth, the readings would not be correct due to many parallel earth paths.
Heating pumps usually give a low reading when hot if they are going down,IR when cold and again when hot and see the difference.
