it will cost about £50 a fraction of fitted wardrobes and then all done properly and safe
thanks worzol99
I assume with this type of patress box a single outlet is fitted to one side and a blanking plate to the other.
thanks for your help
maybe my question was not clear
re-worded question
I have a double socket outlet that is in the way for fitting a wardrobe. the fitter advised removing the socket out let and fitting a single to one side of the patress and a blanking plate to the other.
i have never seen such an item so was after advice and where to find one.
the two gang duel patress box makes sense and would fit to what the fitter was after
the fitter will cut around the blanking plate rather than have half a live socket poking out
Change the back box, and make good easy job really. Fitted wardrobe would cover most of the mess if done properly
thanks all
sorry to those that didn't understand the question at least i now know what i need to do.
just get it moves over 100mm, u cant get a blank plate and sicgle socket on a double plate. like the guys said if you put a dual box in then you could but just be easier to move it
change the double back box to a single and fill the hole, then the wardrobe will fit back against the wall. Simples.
the wardrobe installer who claimed to of been an electrician in the past said
So is he a joiner who used to be a spark or a spark who used to be a joiner? Either way I don't think he's giving you good advice, as has been said just move the socket
