Have used quite often lead quality fairly good and if customer doesn't contact back within 5 days of you contacting them you can claim the lead cost back
some good, some bad. pot luck and a bit of common sense. e.g. if it's a total rewire with an estimated budget of < £1000, stay clear.
i think its a really good system , 9 times out of 10 if your first to buy the lead you usually get the job unless your quote is outrageous,or if they customer requires 3 quotes for bigger jobs,
customers set there budget and you are charged accordingly to that amount 1 customer had a budget of £1000 to change a light the charge for the job was around £40 so look out for those ones there not worth buying .
michael0766,
SLSpark,
