You still need to check if two MCBs need to be off the make the sockets dead.
Yes the first two mcbs need to be off simultaneously in order to have no power in the ground floor circuits including the kitchen. Excluding the cooker which is on separated circuit and rcd.You still need to check if two MCBs need to be off the make the sockets dead.
All sockets have power everywhere so it cant be a matter of live wires being swapped.I just realized that if one leg is swapped with the ring circuit ones then if i tur off the mcb with two lives i still should shut down at least some sockets. I must check all sockets tonight instead of just 6 of i think 9. And if i still have power on all sockets then it cant be the legs that are switched off.
Just indicates which circuits the cables belong to. I assume in this case for that reason and not to identify the legs of the ring circuits which also why it is done, the reason I assume it was not done for the legs is the single cable has a marking and same markings have been put together. The fact you have issues with isolating the circuits points to an identification mix up.All sockets have power everywhere so it cant be a matter of live wires being swapped.
I also noticed the problematic circuit lives are marked with black pen. One horizontal line and then two.
What does this mean?
( The attached file wont show)
Can you view imageJust indicates which circuits the cables belong to. I assume in this case for that reason and not to identify the legs of the ring circuits which also why it is done, the reason I assume it was not done for the legs is the single cable has a marking and same markings have been put together. The fact you have issues with isolating the circuits points to an identification mix up.
If no mark is one circuit, 1 mark is the second circuit and 2 marks is the 3rd circuit of that trio of circuits then it is wired correctly to the markings but it would appear there was some mix up perhaps and cables were wrongly marked.
As pointed out by others you really need the correct test equipment to sort this it might also be two issues combined, not actual ring circuits, rings within rings or interconnects between rings as well as mixed up connections at the board.
It requires testing fully to make sure you have rings where you should and no interconnects etc.
I am not. I imagine price is a factor but i think my best effort surpaces any professional i call.Which part of Scotland?
I am surprised you can’t find an “honest” electrician.
Ps, images workaround. Use the “insert image” above text box rather than “attach file” below.
It could be certain floors in the house have too much electricity so you might want to wear a hat in those roomsHi i am modernizing the single sockets in the living room and so i started to flip the breakers which says ground floor sockets. To my surprise i still had electricity everywhere on all floors! Thank God I checked.
Then I flipped the other breaker which was labeled kitchen sockets. That did the job as there was no electricity anymore on the ground floor on all sockets including the kitchen.
But then wife yelled she had no power upstairs. As i checked the RCD for all 3 breakers had flipped. Upon testing I discovered that when i flip the first two breakers the RCD trips.
Whats going on???!! What could be the possible wiring that can cause this? Thats the quality of working class homes in uk.
Edit: I tested some more today and now rcd does not trip but if i turn off the breakers and touch the isolated sockets live and neutral wires the rcd trips...so it must have tripped before even the curcuit was isolated. So it wasnt isolated till upstairs sockets were also off. What to make of all this? At the board the socket circuits are two rings and one linear if number of wires are indication
Jeez I mark some of my cables with an o after I've exhausted dots and dashes lolI am not. I imagine price is a factor but i think my best effort surpaces any professional i call.
Parcig responce failed.
Will try screenshot. Only inserting links to image upload elsewhere worksView attachment 124847
