leep82
Just wondering, all my training was done towards the 17th edition so i have always known/installed RCD's were necessary in domestic installations.
My mum has recently moved house and when i went round to have a look, i naturally gave the mains a glance. TNC-S supply and a split load board with 100A main switch and 80A 30ma RCD. On the RCD protected side there is kitchen and house ring main, cooker and shower, and off the main switch, lights and boiler supply.
Is this common of earlier editions of the regs? Ive heard of sockets needing RCD protection prior to 17th edition but what about the installation as a whole as there will obviously be cables buried at a depth of less than 50mm which arnt RCD protected.
The reason i ask is that the installation looks relatively new and there is even harmonised colour cable used ( although i suppose this could have been additional work carried out at a later date than original install ), surely somebody wouldnt have installed this to current regs?
new colours came in i 2004, made mandatory 2006. 17th came out in 2008, so this is probably a late 16th installation. i.d not worry about it.
Upvote 0
Harmonised cables introduced 2005. 17th edition introduced 2008 so the installation is very easy to date. Absolutely nothing wrong with it the way it is providing it complies to the 16th.
Upvote 0
Cheers glenn, cross bonding is present on pipework beneath boiler, main bonding is also in place and although i cant see where it dissapears to when i opened the shower there is a 4mm2 green/yellow that dissapears with the supply T+E cable.
Upvote 0
get your test gear out and prove between pipework in locations.....
Upvote 0
Same here. It depends on your degree of caution and how flush you are. Is there a sticker saying when it was installed/last inspected? Getting an Electrical Inspection Condition Report (EICR, formerly PIR) is recommended (but not mandatory) on change of occupant. Or if you got a properly done CU change you'd get the important bits of the EICR done within the cost. Or you could get the lights and boiler circuits upgraded from MCBs to RCBOs which gives them RCD protection. Some would call it overkill, but RCD protected final circuits do save lives, so it's your/your Mum's call. Be careful putting nails in walls in the meantime.
You could buy her RCBOs supplied and fitted for her birthday :)
Upvote 0
It might just blow your mind to know that RCDs are not 'necessary' in domestic installations. No more than they are 'necessary' in commercial installations anyway.
Have a read of the regs and it'll fill you in on the circumstances where RCD protection is necessary and where it isn't.
The chances are your Mum's board is absolutely fine, just not up to current regs.
Upvote 0
You could buy her a CU change for her birthday :)
still at it i sees Nick...
selling unnecessarry `remedials` to the unwary....
to the OP:
as long as it complied at the time it was installed...then alls clear....as long as it passes present visual & tests...
Upvote 0
it may even provide `additional` protection...
what do you think Nick mate?:biggrin:
Upvote 0
