Chapter 53 : 530.3.4. - BS-EN-60947-3 . (( Consumer Units ))
For an installation with a 230V single-phase supply rated up to 100A that is under the control of Ordinary persons :
Switchgear and controlgear assemblies shall either comply with BS-EN-60947-3 and Regulation 432.1. or be a consumer unit incorporating components and protective devices specified by the manufacture complying with BS-EN-60947-3 , including the conditional short-circuit-test . refer
Main Switch controls all circuits .. 17th Edition High Integrity
Main Isolator(s) BS-EN-60947-3 .
BS-7671:2008:2011: P/286
BS-EN-60947-3 : 2009 .. ( British standard )
Switches
Disconnectors .. disconnector (or isolator)
Switch disconnectors , and
Fused combination units
• Disconnector (or isolator) This switch is a manually-operated, lockable, two-position device (open/closed) which provides safe isolation of a circuit when locked in the open-position .. (( being locked in either the ON or OFF position. When locked in the ON position it will no longer operate as an isolator Positive indication of the opening of the contacts is only given when the green stripe can be seen on the dolly.
• Its characteristics are defined 60947-3: disconnector is not designed to make or to break current
R/P 35 . Switch-disconnector - A switch which , in the Open-position , satisfies the isolating requirements specified for a disconnector
R/P 28 . Fused connection unit - A device associated with the (( fixed wiring of an installation )) by which appliances may be connected , and having provision for a (( replaceable cartridge fuse link ))
Spur
Switched fuse connection unit ; in this case .
A switched fuse has a fuse in series with the switch .
R/P 29 . Isolator . A mechanical switching device which , in the Open-position , complies with the requirements specified for the isolating function . An isolator is otherwise known as a disconnector
Manufacturing Standards . BS-EN-60947-3
100A DP Incomer (( Main Switch )) .. Short-circuit 3kA BS-EN-60947-3
Product contents: 100A Switch disconnector.
100A Double Pole . Main switch Isolator(s) BS-EN-60947-3 .
Wylex 100A DIN mounting switch disconnector. BS-EN-60947-3.2.
Product contents: 100A Main Switch
Short-circuit 16kA BS-EN-60947-3
.. Enclosure material / High Impact Polystyrene
Switches
Spur
Wylex 100A DIN mounting switch disconnector. BS-EN-60947-3.2. Product contents: 100A Main Switch
